8th October 2012, 05:33 PM
Sd33 injector pump turning off engine
Hi there, i'm working on a 1980 patrol with a sd33 that i just done the head on and it looks like for some reason the solenoid that controls the injector pump is cutting the fuel. I have checked all the earths and all the plugs and they seem to be ok and the engine will start but after a couple of seconds it will turn off. I have got it to run and disconnected the plug that goes to the solenoid so the truck keeps running until i reconnect it. Any ideas and suggestions will be much appreciated. Oh and the batteries went flat while i was bleeding the injectors and had to jump start it, also its 24v system if that makes any difference. Cheers
8th October 2012 05:33 PM
8th October 2012, 06:04 PM
All good figured it out, the batteries were low let it run for half an hour and shes like brand new.
