Results 1 to 2 of 2
Thread: Sd33 injector pump turning off engine
    Legendary Alitis007's Avatar
    15 Post(s)
    Hi there, i'm working on a 1980 patrol with a sd33 that i just done the head on and it looks like for some reason the solenoid that controls the injector pump is cutting the fuel. I have checked all the earths and all the plugs and they seem to be ok and the engine will start but after a couple of seconds it will turn off. I have got it to run and disconnected the plug that goes to the solenoid so the truck keeps running until i reconnect it. Any ideas and suggestions will be much appreciated. Oh and the batteries went flat while i was bleeding the injectors and had to jump start it, also its 24v system if that makes any difference. Cheers
    15 Post(s)
    All good figured it out, the batteries were low let it run for half an hour and shes like brand new.
