23rd September 2012, 08:26 AM
egt,s
since i fitted the provent last week my egts are about 100c hotter just say i go around a corner accelerate up a bit of a hill to about 60 to 65 it goes to 450-500 it will hit 550 with a bit more of a hit im worried as im goin camping tommorrow with the camper i think im going to hsve to pull over all the time,any ideas on what ive done wrong 07 crd
23rd September 2012 08:26 AM
23rd September 2012, 08:41 AM
Hardcore
Crd run hotter 550 is for di models. How's your boost levels may have bumped off a turbo hose
Such is the rule of honour.
23rd September 2012, 09:06 AM
Need guages to let you know happening, block the EGR, I have a NADDED Di and EGTs are 200 degree C at 100 kph and 10 psi boost
Climbs up to 500 pushed hard
Use the search engine top right hand side ,plenty of info on this topic there
23rd September 2012, 09:45 AM
boost levels are normal nothing has changed there
23rd September 2012, 11:10 AM
Can't see how a catch can can elevate EGTs, sure its plumbed up right???
23rd September 2012, 12:56 PM
23rd September 2012, 04:23 PM
Got nothing to do with EGTs, is your EGR blocked yet? maybe EGR blocked or playing up
23rd September 2012, 08:37 PM
#8
egr not blocked yet have the plate but didnt want to put it in till i get back from holiday put ultra gauge on no faults
23rd September 2012, 09:07 PM
#9
Where I'd your probe located? I find it strange the catch can would be at fault as its only crankcase pressure going through it and doesn't normally have anything to do with exhaust temps. It may be that you are just more mindful of your gauges now you have done some work on it. But the CRD's do run on the hotter side more boost will generally help and a decent free flowing exhaust. Does it still have factory exhaust and also is the gauge in C or F? Cheers
24th September 2012, 05:52 AM
#10
kevin07
dont block egr valve as this will give an error code because there is a sensor in there
glad to see you got your gauge
OH LEATHER IS NICE
