Results 11 to 20 of 27
Thread: buying advice for gauges?
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Monty_e View Post
    Megomonster - are your gauges an LCD? They look real flash and with good contrast. How do you find them in the sun?
    Yes LCD. I have not yet encountered trouble from the sun but I am expecting it.
    Sent from the secret chambers of our secret society, on a secret iPhone, with a secret pin code and eye retina scanning from a secret peep hole, just don't tell anyone OK, cos it's secret........
    Advanced Monty_e's Avatar
    Brisbane, Northside
    Yes please threedogs!
    Thanks Patch!!
    2003 GU ST ZD30 Auto
    Pre NADS: Pyro & Boost Gauges, EGR block plate, Catch-can, Multi Stage Boost Controller (Dawes valve) & Needle Valve ordered!
  4. #13
    Expert snewin's Avatar
    Muswellbrook, Hunter Valley
    I got autometer gauges & a pillar pod off eBay. All up around $300. Very happy with the result.
    Love is a TD42T
  5. The Following User Says Thank You to snewin For This Useful Post:
    Monty_e (7th October 2012)
  6. #14
    How's the serenity boots's Avatar
    Sep 2011
    There is a vendor on the forum who sells gauges . KHOLO ST is his name , PM him and see how you go or search ''autometer combo'' thread with info on whats what . Otherwise ebay is your friend with the strong aussie dollar . My advice is make sure you get boost readings in PSI and EGT in degrees celcious / metric .
  7. The Following User Says Thank You to boots For This Useful Post:
  8. #15
    And don't get a boost gauge that goes into negative, no need. Consensus seems to be 0 to 30 psi gauge.
    Love is a TD42T
  9. The Following User Says Thank You to snewin For This Useful Post:
  10. #16
    Advanced Steveo_the_Devo's Avatar
    Oct 2011
    Wollongong NSW
    X2 Autron gauges & pillar pod. 2 gauges, 4 readings. EGT & boost are in 1 gauge, dual batteries in the other. Boost & EGT alarms built in & adjustable. No problems in sunlight but can be a bit bright at night. They are a bit $$ though
    Tappity tap don't look back
    2011 CRD with a bunch of stuff bolted on
  11. The Following User Says Thank You to Steveo_the_Devo For This Useful Post:
  12. #17
    Brisbane, Northside
    Thanks for all the feedback guys. I've gone the Autometer gauges from eBay... a tad more reasonable than Autrons. Thanks anyway Steveo. Thanks Boots - yeah negative = vacuum.
  13. #18
    This is an option if you want to monitor 2nd battery,
    Red one just a cheapie but hey something to keep an eye on driving along
  14. #19
    brisbane
    heres pic of my gauges, they only block out low rpm's and speeds above 140kh
    and volt meter from baintech best gauge ive seen yet more accurate then needle and is back lit never has an issue with glare
    and auto temp gauge sorry dont have pic from another angle for this one
  15. #20
    Expert Biscuits's Avatar
    Driving the Beerbulance around the Tweed Coast
    Quote Originally Posted by megatexture View Post
    This is where I am planning on putting my boost guage, Will post up some pics once it is in... just waiting on parts, they are on a slow boat from china (very friggin slow boat at that)
  16. The Following User Says Thank You to Biscuits For This Useful Post:
    threedogs (7th October 2012)
