Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: LED strip lights for camping
    brisbane
    I use aluminium right angle 1 mtr and have a strip on each of the two outer faces and use clips that just grap onto a tent pole and also have holes I can zip tie them anywhere these are the sort of clips I use
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    These look like a good bargain. Switch, cable, aluminium strip and led's. 60cm strip for $40-$50
    http://www.ebay.com.au/itm/12V-60CM-...item4172f02280
    1999 GU 4500 dual fuel
    Il dado è tratto
  4. #23
    Jaycar sell all that alloy extrusion and end caps for stip lighting, so easy to tailor make your own
  5. #24
    465 Post(s)
    Quote Originally Posted by NP99 View Post
    You can make three for that price mate.and at longer lengths too.
    @ TD, the Jaycar end caps are rubbish. I went through all this when I was making my strips. I ended up using those square plastic plugs you get from Bunnings for a buck for two. Worked and looked better too.
    I tapped that app...
  6. #25
    Feb 2013
    Broadford VIC
    Indeed, as I made my own, however for the non dyi guys, I think it's a good buy.
    Il dado è tratto
  7. #26
    465 Post(s)
    Yeah good call...
  8. #27
    Jun 2013
    Thanks for the great ideas
  9. #28
    Beginner daniel79's Avatar
    Sep 2013
    San Francisco, CA
    Yes i agree the 5050's brighter but have found the 3528's to be more than adequate for the campsites we have been on.They are less in your face and provide more than enough light. I had the 5 metre lengths of 3528 led strip stringed out across the trailer and under the camper to see in the storage area. they could emit enough lighting for our need.
