Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Spot lights
    Legendary Alitis007's Avatar
    15 Post(s)
    Spot lights
    Hi there, just wanting to know when you wire up spot lights do you use a relay for each light or 1 relay for both ?
    Hardcore healy's Avatar
    south east melbourne victoria
    If they are a pair then just one relay
  4. The Following User Says Thank You to healy For This Useful Post:
    Alitis007 (25th September 2012)
  5. #3
    Yep just one relay for the pair will be fine. Make sure you wire them up to your high beams to please the coppers.
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #4
    15 Post(s)
    Cheers fellers n the jacks can bang it lol nah i'm wireing them up on ther own circuit so i can use them if i need to withought the head lights on when i'm fishing or as work lights.. Thanks as always guys you are a great help!!
  8. #5
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You can get a on/on switch or a on/off/on switch and wire it up so when the switch is in one position the spot lights will only work when the high beam is on and in the other position they will work independently.
  9. #6
    If you're going to wire them to use as work lights, you might want to wiring them to your Aux battery.
  10. #7
    Patrol Guru
    May 2012
    NT
    Some relays (sold as spot light relays) have two terminals so you can run a wire from each spotty to the relay.
    Tipsy-tap
  11. The Following User Says Thank You to P4trol For This Useful Post:
    threedogs (25th September 2012)
  12. #8
    Now I think about it keep it legal and put a light bar or similar on the roof.IMO only
  13. #9
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    In NSW they have to be on only with the High Beam and an on / off switch on the dash for rego pink slips.
    You guys dont get the pink slips down in Vic, so might get away with it. Untill a copper decides to go over the vehicle.
    On the roof as threedogs said and not necasarily pointing forward may fit the work light description.
    Frying a copper before you can turn them off might get you some unwanted attention.
    The suck some amps so the idea of putting them on the aux battery is a good one too.
    Macca
  14. #10
    Western suburbs of Melbourne
    11 Post(s)
    I have 7 spotties, 2 on the bar and 5 on the roof rack. All turn on under high beam and can be switched off under high beam. I also have a separate switch for the 5 roof spotties to work with the car off, wires running to the aux battery
    Sent from the secret chambers of our secret society, on a secret iPhone, with a secret pin code and eye retina scanning from a secret peep hole, just don't tell anyone OK, cos it's secret........
