Results 1 to 5 of 5
Thread: indicators stay on when used at night with h/lights
    Advanced cookpa's Avatar
    Feb 2012
    Tuncurry
    Hi people went 4wding in the mud last week , when i got home i had my right hand indicators all come on and stay on when my headlights or parkers where on also during the day my right brake light would flash very dull when i used my right indicators and also my dash lights would flash too i found a very badly corroded rear tail light harness on the right i replaced that with a new one and changed all the globes front to back on both sides , i believe its an earth problem but the workshop manual does not tell me how many earth cables are used or under the car . i assume its a bad earth or i may have torn a cable off when mudding thoughts anyone ????????
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I would check your trailer plug wiring for damage, you may need to remove the trailer plug and inspect for loose wires.
    I suspect the wire for the RHS indicator is touching the wire for the park lights.
  4. The Following User Says Thank You to Yendor For This Useful Post:
    cookpa (20th September 2012)
    Feb 2012
    Tuncurry
    ok heres the deal , where the main harness comes through the firewall into the engine bay on the drivers side the harness pushes against the inner guard this harness is not covered in anything other than tape so it wears away from rubbing against the inner guard until you have a bit of a meltdown so yeah its fixed now and wrapped in convoluted tubing !
  6. The Following User Says Thank You to cookpa For This Useful Post:
    Robo (30th September 2012)
  7. #4
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thanks for the update.
    That's a strange one, I will have to add it to the memory bank.
    Glad you got it sorted.
  8. The Following User Says Thank You to Yendor For This Useful Post:
    cookpa (28th September 2012)
  9. #5
    Feb 2012
    Tuncurry
    Thanks Yendor it was a beauty to find !
