Whilst this thread is current again. I’m after 3 more ROH Blak Trak 16 x 8 neg 13mm offset in case anyone has some or knows anywhere selling them at a good price. White Trak 2’s would also be ok.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
They look wicked Hodge, can you give me details on where you had them done , how and cost etc? just wondering if you have had ride time on them to check if they chip etc?
Hi mate. That photo is one of few I've collected off the net and this forum. But those are not my wheels. I looked at getting a set powdercoated a while back, after seeing a set on a white GU like mine. But never got around to it. I got quoted $40 per corner at a local powder coating place.
Has any one used the CSA Ranger steel rims? And if so are they any good??
I got a set of CSA Rangers (Black) 15x8 late last year. Haven't had a chance to go off road with them yet but so far I have no complaints. Been on quite a few long trips with them and a lot of country roads (I live out there) and they have done well.
Owner of 1984 SD33T MK Patrol Owner of 1989 TD42 GQ Patrol Previous Owner of a 1988 TB42 DA Maverick
------------------------------------------------------ WARNING: Towballs used for recoveries can, and do kill people and damage property.
if you want any others Chris just yell out mate as my GUIV still sits on these rims today. Really like them.
Thread dig.
Are the flares different sizes, do they hang out more or less on a GU series 1, 2 & 3?
If so what offset would I need to achieve this on a GU 1. Thinking of running a 305/70/16.
What brand rims I should stay away from?
For best results you'll need to sand blast the rims then powder coat so as Hodge says about $40 a rim.
DO NOT powder coat the recess where the wheel nut sits , if you do it will crack off the powder coating and loosen your wheels
the result could be costly. Also think about clear coating them as well to further protect your investment.
@ JC these are 305s fitted to mine
