12th September 2012, 10:25 AM
"Lokka" Diff lock in rear of GU
Has anyone fitted a "lokka" diff lock to the rear of their patrol? I am interested in one due to it's price competitiveness, but a little concerned about the driveability....
12th September 2012 10:25 AM
12th September 2012, 10:32 AM
Advanced
thought about shimming the LSD? probably waaay cheaper and less maintenance?
just my 0.02c worth
12th September 2012, 10:33 AM
Advanced
12th September 2012, 11:17 AM
Had one in previous 4x4 , don't recommend it, Patrols have great LSD. save your money for Pro Locker for the front
12th September 2012, 01:06 PM
I had thought of shimming it - is that only if it is a bit worn out or does it assist even if it is new? I have low KM (135,000KM) so it shouldn't be too bad I would have thought?
12th September 2012, 01:20 PM
You'll find that patrols have the best LSD around. What makes you want to auto lock it? Do you find only one wheel spinning?
It might be better to fit an auto lokka in the front.
Hello from Under Down Under!
12th September 2012, 03:11 PM
Advanced
shimming once fixes up loose lsd,
shimming twice stiffens the crap out of it and makes it awesomely tight
shimming it 3 times.... youve welded the diff
12th September 2012, 03:25 PM
Depends how thick the shims are. Someone on here got a shim off fleabay that was .7mm and was too thick, making the diff pretty much locked. He machined it to .5mm and found it worked perfect. I can't search for the thread atm but you might find it if you search. There may be some other useful info in that thread too
Tap, crackle, pop
12th September 2012, 03:30 PM
Smart like tractor
im pretty sure they dont make lokkas for the rear i think its only detroit that make them. A 0.7mm shim (on ebay) will lock a good lsd. you need about 0.3 or 4. but you need to get that made at a made at a machine shop
96 GQ coil/Cab
08 G6eT
12th September 2012, 03:33 PM
Smart like tractor
taslucas
Tap, crackle, pop
that was a mate of mine he machined up a 0.4mm shim
