31st January 2015, 03:03 PM
Wissling Noise
Can anyone help me with this . I have a whistling noise coming from under the bonnet mainly just when I start of up the road after put the foot down A little . have checked the belts put new belts on its like air whistling out of something but after a little while it stops . thank you for your time and any help you may give . PS. Its a Nissan Patrol wagon 2001 ZD 30 TDi
Email: rod1169@hotmail.com
31st January 2015 03:03 PM
31st January 2015, 03:31 PM
look at your manifold gasket and have the manifold plainned
31st January 2015, 03:34 PM
I can hear the turbo whistle on mine, has the noise always been there? of is it a new noise?
31st January 2015, 03:49 PM
Symptoms do sound like a leaky Exhaust Manifold or cracked/broken EGR Pipe
31st January 2015, 04:17 PM
X 2 with Happy check the egr pipe for cracks if thats ok,
check the exhaust manifold they are known to warping
31st January 2015, 04:34 PM
yes or could be the intercooler or piping split which is fairly common, check intercooler hoses are tight and run you finger around the seams on the intercooler to check for oil or a dirty looking spot on the welds to check it hasnt split at the seam or weld
31st January 2015, 04:48 PM
Any performance changes or just the noise?
31st January 2015, 05:05 PM
As Stropp says if the IC is oily chances are its FOOBAR and needs replacing with a tigged one.
You could put an EGR blocking plate in to see if its that, but sounds like you need to NADS your Patrol
31st January 2015, 06:02 PM
Administrator
Stropp
Same thing happened to our work car zd30 2000. Small split in the ic, could hear it on start up but went away shortly afterwards when it heated up and closed the split enough for the noise to stop.
31st January 2015, 08:57 PM
To check if its the exhaust gasket (warped manifold) place a rag over the end of the exhaust pipe while it is idling. Don't fully block it but get it to build up some back pressure and if the whistle sounds then you know where the problem lies. Otherwise it could be intercooler or hoses, as others have suggested.
