Results 31 to 38 of 38
Thread: What On-Board Diagnostics protocol does your Patrol use
  1. #31
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The TD42Ti would probably still use the Nissan Consult system. If there's anything available, it would be on the Ecutalk website.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    Cuppa (3rd March 2017)
    194 Post(s)
    My uncle's 97 GQ has both plugs for diagnostics
    Where are these plugs located? Are they on short 'flting leads under the dash or somewhere else? I have a 07 GQ, was a 2.8 TD before chev conversion. I want to configure a trip computer for fuel usage and might be able to use the data ports for this.
  5. #33
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by PBBIZ2 View Post
    I believe they were both up under the dash near the steering column
  6. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    PeeBee (3rd March 2017), redrat (7th July 2017)
  7. #34
    Feb 2017
    Perth
    Hello,
    would anyone know what works on my Patrol TB45E Y61 1998?
    This is my OBD plug:
    I followed the link to the NDS website, but still unsure of the right answer.....
    Is there a bluetooth adapter that will work?
    What software can I use with my android device?
    Keep smiling!
  8. #35
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Quote Originally Posted by Spiv View Post
    Hello,
    Keep smiling!
    Pretty sure the early gu tb45 was still using consult.
    Use NDS on your android. Not much else will work (or is updated anymore)
    As for bluetooth adapters there are a few on ebay you can pick up . Also check the supported devices list for more info on the NDS site
    2002 GUIII Ti 4.8
    Details here
  9. The Following User Says Thank You to Mike02Ti For This Useful Post:
    NissanGQ4.2 (29th March 2018)
  10. #36
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    1990 GQ td42.. when it stops shaking i have a problem...
  11. #37
    Aug 2010
    17 Post(s)
    Was this meant 2 be in the What makes you angry thread @garett?
  12. #38
    Feb 2017
    Perth
    Quote Originally Posted by Mike02Ti View Post
    Thanks Mike,
    sorry for not replying earlier, had and still having family dramas.
    I'll follow your advice and get back with results ASAP.
    Keep smiling
    Stefano
