Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: What On-Board Diagnostics protocol does your Patrol use
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    If you know what Diagnostics protocol your Patrol uses please let me know your Model of Patrol and the protocol used
    Example, mine is
    Model: 1992 GQ LWB 4.2 EFI
    Diagnostics: Consult
    Toddie
    TD42 diagnostics: Common Sense
  4. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    BrazilianY60 (28th February 2023), NissanGQ4.2 (8th September 2012), philfree (4th December 2012)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Example, mine is
    Toddie
    I think all patrols use consult but just different versions
    Model: all CRD Patrols
    Diagnostics: Consult III which includes CAN bus(OBD2)
    ________________________
    ______ 2017 D-Max _______
  6. The Following User Says Thank You to Maxhead For This Useful Post:
    NissanGQ4.2 (4th December 2012)
  7. #4
    Aug 2010
    17 Post(s)
    I think they use OBDII as well, I know some Patrols have the ODBII Plug but use the consult software
  8. #5
    Aug 2010
    17 Post(s)
    My uncle's 97 GQ has both plugs for diagnostics
  9. #6
    ACT
    All Nissan vehicles use consult software. Just different versions and different plugs.
    The CRD is 16pin DLC connector which most OBD2 compliant vehicles use
    Hopefully someone can confirm this
  10. #7
    Aug 2010
    17 Post(s)
    Well even if its still consult, if there is different versions that's the info I'm after and also the different plug types
  11. #8
    ACT
    Yeah the 3l DI was consult II and 14 pin plug from memory
    The 2.8 and 4.2 were consult I... Might be just late model 4.2td
  12. The Following User Says Thank You to Maxhead For This Useful Post:
  13. #9
    Aug 2010
    adelaide
    mine is 11/07 and i use ultra scangauge
    OH LEATHER IS NICE
  14. The Following User Says Thank You to my third 256 For This Useful Post:
    Jim-m-72 (14th November 2012)
  15. #10
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    2009 TB48 = No friggen idea lol
    www.swat4x4.com
