Results 21 to 30 of 38
Thread: What On-Board Diagnostics protocol does your Patrol use
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I just got the bluetooth OBD11 , fits the diagnostic outlet
    All vehicle after 2001 I think, have to have OBD11 in easy reach of of the driver.
    How do you find it threedogs, you you use lappy, tablet or smartphone for read outs?
    Expert Bloggsy's Avatar
    Perth WA
    Thanks Darren, And I thought this thread was dead
    No worries, but it was NeilP that revived the thread. I hadn't seen it before.
  4. #23
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Model: 2002 GUIII Patrol TB48DE (4.8L)
    Diagnostics: Consult II via DLC (OBD) plug
    Adapter Used: Bluetooth ELM327/OBDII adapter from Jaycar
    Program used for diagniostics : NDSII android app. Works well but is pretty basic. You can however scan and clear most error codes.
    I will be trying others and will update on progress as I find out more.
    Torque Pro at this stage will only connect but will not read PID's. Will have a play around with some more settings and see what happens.
    2002 GUIII Ti 4.8
    Details here
  5. The Following 2 Users Say Thank You to Mike02Ti For This Useful Post:
    jay see (4th July 2016), NissanGQ4.2 (4th July 2016)
  6. #24
    Jun 2016
    Rockingham WA
    4 Post(s)
    Update:
    I connected up to Car Gauge Pro. Works quite well but you can not see Oil pressure or temp as apparently there is no output from the ECU on that. Would have thought so myself , but anyway.
    I can get more data out of this than NDSII android app. Both only read the ECU and no other computer on the car though. So you miss out on gearbox temps etc.
    I know NDSII for windows will read all available computers but the Android app will not
    I have heard that Torque Pro will be supporting Consult II in the next update
    The issue has been Torque Pro has been based on a 4 Byte protocol and didnt support the 5 Byte protocol which was needed for Consult II
    So this is good news as it seems to be the only one receiving regular updates and support.
    Car gauge pros last update was early last year and I have found no word on any kind of update
    2002 GUIII Ti 4.8
    Details here
  7. The Following User Says Thank You to Mike02Ti For This Useful Post:
  8. #25
    174 Post(s)
    Can anyone tell me what diagnostics my '06 TD42i has? There is a plug under the dash which Bob connected his laptop to. Gave very limited info - RPM is all I remember. I'm interested in the system which gives flashing light codes for problems - how it's accessed, & what it can tell you. I vaguely recall there being x number of flashes means xyz??? Can anyone tell me more?
  9. #26
    174 Post(s)
    Can anyone tell me what diagnostics my '06 TD42i has? There is a plug under the dash which Bob connected his laptop to. Gave very limited info - RPM, engine temp & battery voltage. I'm interested in the system which gives flashing light codes (blink codes) for problems - how it's accessed, & what it can tell you. I vaguely recall there being x number of flashes means xyz??? Can anyone tell me more? @Yendor
  10. #27
    175 Post(s)
    Cuppa. Our 4.2s have the consult plug.
    I've had the ecu cable plugged in with the ecu talk program.
    It reads your usual stats like rpm , coolant temperature temperature , airflow , injector timing etc ...
    However I don't think this can read any stored codes ???
    Someone correct me on this.
    Have a read of this.
    http://www.ecutalk.com/diesel.aspx
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Do you mean checking fault codes manually by bridging OBDII plug?
    http://www.nissanpatrol.com.au/ZD30-...san-Patrol.pdf
    Page 14
    Have tried it bit did not get any codes.
  12. The Following User Says Thank You to VK2FMIA For This Useful Post:
    Cuppa (3rd March 2017)
  13. #29
    Patrol Guru
    Jul 2014
    6 Post(s)
    RB30 Carby, diagnostics done by it's owner haha. Compression, fuel, spark, work from there.
  14. The Following User Says Thank You to Throbbinhood For This Useful Post:
    mudski (2nd March 2017)
  15. #30
    175 Post(s)
    Quote Originally Posted by VK2FMIA View Post
    Page 14
    That is for the zd30. ObdII protocol .
    TD42 is an entirely different setup.
    As I said i think the TD42 doesn't have a computer capable of retaining fault codes.
    Once again. Happy to be corrected.
  16. The Following User Says Thank You to Hodge For This Useful Post:
