Results 21 to 30 of 37
Thread: top shock mount stuffed. HELP.
  1. #21
    North brissy
    I know its been said before but grab yourself a die nut that way you can re thread it using a spanner. Die nuts are good as you dont need the T style handle you can just use spanners,sockets etc. You should be able to get one of these in there as it will be the same as getting your spanner in there to undo the shock mounting nut. Failing that it looks like a cut and re weld.
  2. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    dan dog (8th September 2012), patch697 (8th September 2012)
    sunshinecoast
    3 Post(s)
    x2 on the die nut . Just make sure you thread it on the right way ( tappered threads first ) and go easy and let it pick up the old thread and use lube .
  5. The Following User Says Thank You to nipagu7 For This Useful Post:
  6. #23
    Nov 2010
    Lobethal, South Oz
    die nut x3, they are awesome for spots like this!
  7. The Following User Says Thank You to mrflibbles For This Useful Post:
  8. #24
    Legendary happygu's Avatar
    Dan Dog,
    This is what we are talking about....
    Where you can use a die handle, and even unscrew one of the handles to get around the difficult spots, or just use a spanner or shifter.
    Mic
  9. The Following User Says Thank You to happygu For This Useful Post:
  10. #25
    Thanks everyone. Didn't even know you could get them nuts. I was thinking big T handled die. I'll give it a shoot. Again thanks for all your input.
  11. The Following User Says Thank You to dan dog For This Useful Post:
  12. #26
    VICTORY. Nut die worked a treat. Thanks everyone for your help. So happy right now my. @rse cheeks are clappin.
  13. The Following 2 Users Say Thank You to dan dog For This Useful Post:
    mrflibbles (8th September 2012), patch697 (8th September 2012)
  14. #27
    Nov 2019
    Melbz
    Alright, thread dig.
    I have a problem with mine except mine snapped off and have been searching high and low over the internets and I'm out of ideas on how to fix mine. Pics incoming.
  15. #28
    Nov 2019
    Melbz
  16. #29
    Nov 2019
    Melbz
  17. #30
    Nov 2019
    Melbz
    Anyone got any ideas? Or I'd best cut my losses and part it out?
