Results 1 to 10 of 13
Thread: Not possible to engage 4L on 99 GR 2.8tdi
    Advanced OhBugger's Avatar
    Aruba
    Well, the title says enough: i can't engage low gear. When i push down on the gearstick it doesn't go down so i can't shift to low.
    Anyone else have this problem or knows what i'm doing wrong (since i'm a 4x4 newbie...)
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Check the mechanism under the car, it could be seized from rust or full of mud.
    Get someone to try the lever while you watch underneath.
    Could be damaged also.
    The selector rods could also be damaged or seized.
    How long since 4low has been engaged?
    Let us know what you find.
    Feb 2011
    Shed
    45 Post(s)
    You must be in neutral and stopped or going very very slow
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    You might need to take the floor up and check that something hasn't fallen down around the gearstick.
    Have you tried tapping it with a rubber mallet?
    The linkage might need adjusting.
    Cheers, the ferret.
    Aruba
    When i tried i was standing still and had the car in N.
    I heard from one of our mechanics on base that the previous owner got stuck in very salty mud, and didn't clean it for a while.
    I'll check underneath...
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by OhBugger View Post
    Very salty mud??? OHHHHHHH bugger.
    Cheers, the ferret.
    Aruba
    Quote Originally Posted by the ferret View Post
    Cheers, the ferret.
    Yep, and they conveniantly failed to mention it...
    Feb 2011
    Shed
    45 Post(s)
    Wash Wash WAsh coupla cans of WD40 or similar and gentle tap on transfer with rubber mallet to try free up
  10. #9
    Aruba
    Well, a couple of bangs and some wd40 solved the problem. Thanks guys!
    I don't think the previous owners used 4L a lot...
  11. #10
    Feb 2011
    Shed
    45 Post(s)
    Beauty good to hear it wasn't anything worse
    Tap tap drip drip
