19th June 2010, 08:18 PM
Removing LPG from 4x4.
I'm strongly considering this as It's running straight gas and I like to spend money and time on silly things..haha
I just really want to run straight petrol for many reasons such as if you run out of gas in the middle of nowhere you could be in deep trouble, etc.
I'm not the most knowledgable bloke when it comes to gas systems but is it DIY job to just remove the cylinder and everything related to the system or leave it to the pro's?
19th June 2010 08:18 PM
22nd June 2010, 07:45 AM
I removed one a long time ago.
Just make sure the gas is turned off before anything.
There's not much to it really, take the bottle off and everything related to it, just follow it through the system is the best way.
The electrics should be easy, It's just positive power, earth and signal line from the coil.
Good luck!
11th September 2010, 11:13 PM
Do you still require help with this. I have extensive general LPG knowledge.
Mike
