Results 1 to 10 of 20
Thread: Drop boxes for 2" lift
    Jul 2012
    Hobart Tasmania
    Ok So i have a 2" lift installed and although caster is juts ok, i was wondering if anyone is using drop boxes, like zordoes, to give them more caster on a 2' lift which in turn gives more flex out of the front.
    Also, for all those who are doing a small lift, the front stock swaybar links can be utilised by making up a spacer to drop the link back down, I used some rod i had at home, machined up about 20mm long and hay presto, works a charm. You need to compress the bushes to get the nut on with but works just fine.
  2. The Following User Says Thank You to WogsRus For This Useful Post:
    spacekadet (29th August 2014)
    22 Post(s)
    how does more castor give you more flex.???
    96 GQ coil/Cab
    08 G6eT
    Jul 2012
    Hobart Tasmania
    Not castor, you get more flex by lowering the pivot point of the front arms, thus allowing more flex. Well at least that is the theory.
    330 Post(s)
    Hi Mate,
    you will find that running a 2 inch lift you will be no where near the limitations of the pivot point and your limitation will be the sway bar and the length of the front shocks.
    Fitting drop boxes is required primarily for Caster Correction and it would be argued by most that NO Caster correction is required on a 2 inch lift. Fitting Drop Boxes will cause an over correction and massive oversteer and really vague response i reckon.
    At the end of the day mate there is no "Quick Fix" Your limitations are your 2 inch lift. Full Stop. All good for most and will get the job done but when chasing the next level it becomes "All In"
    Hope that makes sense?
    Cheers MR
    Jul 2012
    Hobart Tasmania
    Thanks mate
    The front shocks are matched to give maximum front travel, Extended Length 21.310 in. Collapsed Length 12.550 in. so should be just nice, the front sway bars are currently mounted at 5 degrees down from horizontal and give an extra 10cm of travel VS horizontal mounting.
    I did experiment on the weekend, and found if i drop the pivot down 30mm, the over all travel increased 180mm with sway bars in and so forth.
    330 Post(s)
    Quote Originally Posted by WogsRus View Post
    Thanks mate
    hmmm? but based on the length of your shock you have a total available travel on the shock of 223mm only so to have an increase of 180mm are you saying that you only have 43mm of travel now?
    21.31in (541mm) Extended length
    12.55in (318mm) compressed length
    8.76in (223mm) Total Available Travel
  9. #7
    22 Post(s)
    I understand that but you did say that more castor and therefor more flex.
    On a patrol the big limiting factor is the distance between the radius arm mounts on the diff. On a patrol it is 230mm between mounts. An 80 series flexes better because they are 180mm, apart and a landrover is even better still and 150mm (from memory) The closer they are together the more the bushes are allowed to move. from this the roll resistance is less and handling is comprimised and that why a superflex arm only has 1 superflex arm not 2.
    if you want flex from a 2 inch lift you need big shocks. if you want to go really big you need to sit down and engineer a solution to get everything right ie anti-sqat and anti dive geometries, instant centre etc. and if you are going that far I would just double triangulate the rear and a 3 link + panhard front
    96 GQ coil/Cab
    08 G6eT
  10. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (3rd September 2012)
  11. #8
    Jul 2012
    Hobart Tasmania
    Not castor direct sorry.
    The shocks i have are 2.75" extra over stock, when i measured my stock shocks, they only have 145mm of travel. GU8 that is. The measurement i am talking about extra travel is based on taking out the stock shocks and seeing what i can get away with in terms of travel and the stock mounting points and sway bars. Sorry should clarify the travel was split left right, so 40mm up on one side 40mm down on the other, ie crossed axle, i don't know how to explain it all but i know it works. LOL.
  12. #9
    330 Post(s)
    The real problem with the theory is that your spring length is all wrong. Regardless of the Mathematics of your Flex you are governed by the Drivability of your car. Installing Drop Boxes into a car that is sitting on a 2" Spring will drop the back of the Radius arm below horizontal and create a massive over correction problem and the thing will steer like a Boat and put a heap of weight on your steering box due to the extra power needed to steer as a result.
    It is not all about the flex, The thing needs to steer too.
    If your hell bent on getting flex then you have to go to at least a 3inch spring or at best have some small compact Drop boxes custom made but i think your playing with fire.
    Go a longer spring and then get into it mate. If your worried about staying legal then you cant fit drop boxes anyway??
    Here is my GIUV running a 3" Old Man Emu lift with Drop Boxes. No extra length shocks installed. Just out of the box OME Comp Spec. Note i have not refitted the front sway bar but have installed the rear sway bar only. The car is sitting on 285/75/R16s
    Just the back fitted
    Front done with Drop Boxes
    Sits great with a Loaded Trailer and Loaded car for Touring
    And the Front works really really well!
    Got to be happy with that!
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    skiman (18th May 2015)
  14. #10
    Jul 2012
    Hobart Tasmania
    Thanks for the info, i guess we will see how it all works in real life and go from there.
    ta
