2nd September 2012, 02:24 PM
Hardcore
gu zd30 gearbox drain plug
Hi guys just doing some services. I bought my oils parked the car up slid under her to drop the gear box oil to find the drain plug seized. I tried rattle gun, breaker bars wd40 nut and rust remover anti seize I even fired up the oxy still could not budge.
Now after my hard work I've stripped the part where you insert the halfinch socket. Does anyone know where I can buy a new drain plug from as next weekend I'll be drilling and easy outing the drain plug so I'll need to replace the drain plug
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
2nd September 2012 02:24 PM
2nd September 2012, 02:52 PM
I'd be going to Nissan for a replacement plug.
GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
KEEP OUR TRACKS LITTER FREE!
2nd September 2012, 03:29 PM
Weld a piece of steel to nut it'll come straight off.
Get one of those magnetic jobs if you get replacement plug.
2nd September 2012, 04:18 PM
Hardcore
We would have done so but welder of ours is at bigrigs house doing the panels on his sons car. Next week I will do something like that but need a new one as its too flogged out
2nd September 2012, 04:22 PM
I had the same problem with mine. I got a new one from Nissan.
I also welded a bar to mine rather than drilling it out. Have fun Macca.
2nd September 2012, 05:09 PM
Hardcore
cheers guys I'll ask Nissan or a wreckers and prepare to part with my left nut for it then. I once bought a part from them for my vl it was a little radiator hose and was 32 bucks for about 10 cm of 1 inch hose
2nd September 2012, 07:24 PM
Lending tools, A good thread for the future. At least you know where it is
2nd September 2012, 07:43 PM
Hardcore
Start a tool co op for all the expensive tools too.
10th September 2012, 05:32 PM
Hardcore
so I finally got a chance to call up Nissan as wreckers wouldn't pass me one. $30.05 for the gearbox drain plug ouch but last thing to do before the forum meet.
