Results 1 to 3 of 3
Thread: Fitting a steel tray off coily onto leafy
    Expert CorbinsGUte's Avatar
    May 2012
    Townsville QLD
    Hey guys , just wondering if a tray off a 2005 gu coil ute fit straight up onto my 2008 leafy ute? Are the mounts spaced apart differently on both utes as I know mines a bit longer then a coily. Cheers
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Hi.
    The mounts are wider on the coil chassis and there are 3 a side.
    There are 4 a side on the leaf chassis and spaced differently from front to back.
    Trays like Triple M have mounts that are adjustable front to back and have the holes for both chassis widths in each mount.
    Hope this helps.
    Cheers.
    North brissy
    As above mate. If you do a small amount of work they will still fit
