Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Fumes in cab
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Fumes in cab
    G,day all, I'm having problems with exhaust fumes entering the cab after heavy acceleration, especially with a window open.
    The exhaust bloke fitted all new studs at the exhaust manifold and modified the engine pipe flange to fit a solid gasket. I can't see or hear any leakage from the exhaust. I've checked the rear door seals, added an extra seal of foam tape and checked the air vents on the rear pillars.
    Last edited by mudnut; 31st August 2012 at 02:31 PM. Reason: To make a new thread for second Question
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    mudnut,
    It might pay to check all the grommets in the engine bay and any that might be underbody. Check around where any wiring looms, A/C and heater pipes enter the cabin area. Also check the plates on top of the transmission tunnel where your gear levers are.
    Also check along the rest of the exhaust pipe to the rear of the car for leaks.
    Mark
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
  4. The Following User Says Thank You to MC97GQ For This Useful Post:
    mudnut (31st August 2012)
  5. #3
    Patrol Freak
    New exhausts stink for a while as well especially if they have painted them on the joins etc.
    Might pay to check the bungs in the floor as well.
  6. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
  7. #4
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi mate, your better of posting up your second question in a new thread otherwise it might get missed.
    Todd
  8. #5
    Make sure you drive with the windows down or you'll get one hell of a headache
    Agree with 97lwb there is a coating that will need to be burnt off, maybe go for a 1hr drive
    find some puddles. these fumes are deadly, be carefull eh.
  9. #6
    Patrol Guru The BigFella's Avatar
    May 2012
    We are located in the Port Stephens region of NSW, sand, water and fun in the sun!
    check to see the seals around the rear barn doors havent gone shiny and hard?
    If they have they wont seal properly.
    The BigFella
    500,000ks and still counting!
  10. #7
    Banned
    Are you sure its exhaust fumes your smelling & not gunk buildup burning of your engine???
    Its not always easy to distinguish the difference...
    The other thing to check for is hairline cracks in the exhaust manifold, a common problem with Patrols & not always that easy to spot.
  11. #8
    Patrol Guru
    Apr 2011
    Melton
    Is the exhaust running out the back of the truck - ie standard?
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  12. #9
    22 Post(s)
    Hey mate the fact that you smell it after heavy acceleration tells me that the hose from your crank case vent (located on the rocker cover above the 6th cylinder to you air box) may be disconnected.
    I'm guessing this as I have recently put an intercooler and didnt have anywhere the connect the CCV so I left it of whilst test driving and waiting for a catch can to arrive. I could smell it after being on the throttle
    96 GQ coil/Cab
    08 G6eT
  13. #10
    SW Vic.
    80 Post(s)
    Quote Originally Posted by patch697 View Post
    The engine is pretty clean, so I suppose I'll have to take that cover off and check for cracks. If it is I'm thinking of putting extractors and a hi-flow on to boost power anyway.
