27th October 2010, 05:58 PM
does chem i weld work
hey have been getting water in oil but not oil in water ,replaced head gasket but problem still exist so was thinking the head is cracked and looking for a cheep fix
27th October 2010 05:58 PM
27th October 2010, 07:50 PM
Hardcore
Mate, Chemi weld and Barsleaks, all good in an emergency, but you should remove the head again and have it crack tested, it may just be warped, All these products are only temporary and hide the problem for a while, but it will get worse I can assure you, sorry I can't give you a quick fix.
27th October 2010, 07:56 PM
thanks ferret was thinking the same thing but you never know
9th November 2010, 05:25 PM
YMMV (your mileage may vary) but it's a quick fix and NOT a solution!
1st December 2010, 07:48 PM
flush her out and go a bottle of irontite follow instructions top stuff still cheating
1st December 2010, 10:32 PM
Yep still working after a couple of months ,2 spare good motors in the shed so if it dies i'll just change the whole motor.
90 maverick LWB 2" lift,General Grabber a/t
92 Coil Cab 3" lift, kl71 33"s n/a td42
2nd December 2010, 06:39 PM
it has worked for now stopped getting water in oil see what happens thanks for your replies .
