Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Replacing front crank shaft seal TB42
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Just looked under my tb42e and it looks like the front seal is leaking. Once the harmonic balancer is off, is the seal easily accessible? Just remove old one and insert new one?
    Edit: never mind found some pictures, just pry old one out and gently press new one on evenly.
    Is the crank bolt a typical lefty loose to undo?
    Apr 2011
    Melton
    I have used the crank the starter technique a couple of times to undo the crank bolt. - I didn't like it the first time but I had tried all the other metdos .
    The only other way is to make a wedge that can be used on the fly wheel teeth.
