27th August 2012, 06:43 PM
BIG & BALD
Bigrig
New turbo and intercooler would be my thoughts - but even then the gains would be modest I'd reckon ...
Intercooler upgrade is about 4th or 5th on my to do list.
Gauges. Lift. Tyre's. Winch. Intercooler.
27th August 2012 06:43 PM
27th August 2012, 06:46 PM
BIG & BALD
Steve4wdin
It sounds like the same issues I had. I suggest getting a dyno done and boost control. It worked wonders on mine. 119rwkw. Mine is GU7. Did you fit the DP Chip yourself?? I think they have different settings don`t they?? If you have dyno done, they can set fuel mixtures to suit the chip setting. All the best
Dyno I haven't done yet but is also on the cards. How does a boost controller help.
27th August 2012, 07:12 PM
Mego, with the DP Chip and the 3" exhaust - we shouldn't be able to catch you.....
Mic
27th August 2012, 07:22 PM
needle valve when dynoed will dial in your spool up rate for optimum performance,
everything will work when its supposed to, getting mine done soon, I'll let you Know how it goes
27th August 2012, 07:24 PM
BIG & BALD
happygtu
Mic
It's still a 4 cyl
27th August 2012, 07:45 PM
MEGOMONSTER
With a bigger exhaust, tuning the motor to chip, setting chip to engine, etc, you can end up with over boost issues as I did. Put a dawes valve and needle valve, you can control the max boost to avoid this. I think by memory max is
22lb but you don`t want to exeed 18-19lb.
1st September 2012, 10:05 PM
#17
BIG & BALD
Is a new air box going to help me any
22nd July 2013, 01:18 AM
#18
BIG & BALD
MEGOMONSTER
I found this, question above still stands.
http://hpdiesel.com.au/nissan-patrol...30-air-box-lid
Now I only have the Nissan Snorkel, does the above only work with larger SS or aluminium snorkels.
22nd July 2013, 08:56 PM
#19
The ad says that the standard lid is good for 120rwkw so it might not do a lot...
What tyres are you running? Maybe changing diff gears is a better way to go?
GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
KEEP OUR TRACKS LITTER FREE!
22nd July 2013, 09:05 PM
#20
You could try selling the DP Chip and getting the Unichip or the Dominator ChipIt chip....
