25th August 2012, 05:26 PM
Advanced
GQ Starter Motor
Hey Guys, anyone know if you can get a high torque starter for the 4.2L and if so where from before I start the tedious job of searching thanks.
25th August 2012 05:26 PM
25th August 2012, 05:52 PM
It's funny you ask today of all days lol my starter crapped itself no doubt due to the water inside it .
I had a spare one here that was a reduction starter i put in starts first touch of the key.
It was an aea electronics.
http://www.pinpoint.aea.com.au/Login...2fDefault.aspx
The Following User Says Thank You to 97_gq_lwb For This Useful Post:
roadthumperpatrol (25th August 2012)
25th August 2012, 06:48 PM
Advanced
Awesome thanks, now to find larger injectors and a programmable computer management system for the fuel and timing, I have one for gas but after one for the petrol system as well so any knowledge on systems that work better or compatible larger flow injectors from other vehicles would be appreciated otherwise good hi-flow injector guys, anyone running a microtech system with dyno results on the 4.2L I'd be keen to look at your setups
25th August 2012, 07:39 PM
Nistune http://www.nistune.com/
I would go a factory live tunable ecu for a road vechile over aftermarket any day they are already set up to suit and need minor changes to the tune for changes.
25th August 2012, 07:46 PM
Advanced
Should have mentioned it was petrol hehe, might have found one tho fingers crossed, any recommendations on head work (porting polishing and strengthening) in and around Logan and Gold Coast QLD would be appreciated!
25th August 2012, 07:54 PM
Advanced
Cheers realtime tuning it the key I'm after defiantly going to try this one out first!
