Results 21 to 30 of 31
Thread: Fitting GU Recovery plates.
    Jul 2012
    I took note of the work done to ad another plate, that got me thinking of doing the same thing, the same way.
    I have a couple of questions.
    Who can i get them from off here and how much, you can PM me if you wish.
    Second question is this.
    Has any one adapted the plates together, by that i mean a cross member from 1 plate to the other using the existing unused holes in the plates ?
    I intend to machine a bar of 50 mm dia with tapped holes in the ends to slip in between the plates to remove any independent side action when both are used together as one ?
    Any feed back on the idea will help.
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    Quote Originally Posted by optic View Post
    Threedogs is the man to speak to. He makes the originals and would probably be able to answer any questions you have re fitment options.
  4. #23
    88 Post(s)
    Just send a PM , SORT IT OUT QUICK ENOUGH
  5. #24
    In Moderation
    280 Post(s)
    Threedogs is the man for recovery plates. Also I can't see how your idea would work or be better than having just recovery plates. Seem a lot of work for something that will be no more efficient than two plates...Just a thought.
    Edit :beaten by the man himself. Also upon re-reading your post I think i get the concept. Seem logical but using a bridle strap should take out any sideways movement in a snatch. Unless your getting snatched out on an angle.
  6. #25
    88 Post(s)
    Don't try and over complimpate a proven system . this is KISS .like I said just PM or pop over, easy to sort out, easier the better IMO
  7. #26
    Patrol God bigguwesty's Avatar
    40 Post(s)
    I see your point but I'm pretty sure the points of which TD's recovery points attach to is not far from a factory cross rail. Given that and that you usually have a bull bar fitted up front to hold chassis apart I think a spreader bar across the chassis would be pointless.
    And a waste of money.
    Owner of
    Westy's Accessories
    In Moderation
    280 Post(s)
    Fixed the original posts as the pics somehow disappeared....
    threedogs (27th July 2016)
  10. #28
    77 Post(s)
    Thanks for this helpful thread Marko. Looks like this is what I'll need to do with my GUII.
    When you have to shoot, shoot.
    Don't talk.
    ~Tuco.
  11. The Following User Says Thank You to Plasnart For This Useful Post:
    mudski (11th February 2019)
  12. #29
    77 Post(s)
    Thanks again @mudski, did this on mine today.
    Don't talk.
    ~Tuco.
  13. #30
    In Moderation
    280 Post(s)
    No problem mate. Glad this old thread is still helping others...
