Results 1 to 7 of 7
Thread: 4.8 rough idle only when cold
    Beginner Jimmycrackcorn's Avatar
    Jul 2012
    I was wondering if anyone has had some experience with an erratic idle to the the point of stalling at times only on cold starts.After 20 secs or so it is back to normal and and no probs till next cold start.2002 gu3 4.8 ti 150k on clock petrol only.cheers..
    It's not the mistakes you make it's the way rectify them that makes the difference...
    Legendary Alitis007's Avatar
    15 Post(s)
    Usually its related to a coolant temp censor but they can be a bit expensive but what you can do is clean your AFM but be carefull not to wreck the little filament in it and also clean the idle speed motor and lubricate it try not to break the gasket. You can use carby cleaner and crc / wd40 to lub. Cheers
    Jul 2012
    Have checked resistance of temp sensor in different temp water seems to be operating within specs..got quoted 92 dollars for temp sensor ,happy to replace the original if i could fault it.
    I will check your suggestions and see how I go.thanks for your input.
    15 Post(s)
    Might awsell do a static tune aswell like air & fuel filters and spark plugs if ther not platnum i change mine every 10k regardless of condition and clean the throttle body, i always say you only get out what you put in! Also check the resistance of the leads and check the condition of the rotor button and cap while you there it might not have anything to do with the fault but atleast you might be able to eliminate those simple things aswell.
    Oct 2011
    Morayfield. Queensland, Australia
    What leads & what rotor button and cap? It is a 4.8 and has none of that.
    David
    15 Post(s)
    Quote Originally Posted by Xtreme 4x4 Sport View Post
    David
    Sorry mate was thinking of my 4.5 haha if its got coil packs with an ohm meter check the resistance of the primary and secondary circuits
    Oct 2011
    I knew you meant that
