Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: is a body lift that great?
  1. #21
    North brissy
    I dont think body lifts are that great at all. all it does is raise you centre of gravity. no extra chassis height or travel
    thats my opinion anyway
    Its actually the opposite. With a body lift the chassis stays where it was with all the engine and gearbox etc still mounted to it. So when you do a 4" suspension lift your COG will actually be higher than that with a car with a 2" spring and 2" body lift. I dont mind the body lifts as you can fit 35's under a car with the 2-2 combo getting the biggest killer of traction (diffs bottoming) further off the ground. As its been said a 2" body lift and 2" spring lift is legal here in QLD I have been told this by the QLD DOT inspector at the pits (dont ask ).
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by growlers71gq View Post
    I thought Scotty got engineered and legal with 4"
    5" actually ... and I have the engineers certificate to prove it ...
    It's listed as a 2" lift coz its only a hairs breadth above this height from standard due to being flexi coils. Ryan's 3" sits as high if not marginally higher than mine - but the beauty of my lift is that due to the pre-load, I get shite loads of travel. The height reg is not based on the spring ladies and gerbilmen - it's based on the ride height of the vehicle post fitting. So if you go a bigger lift, but in a flexi coil that means the truck sits lower than an actual 3, 4, or 5" spring lift, so you still get passed and reap all the benefits of huge flex.
    Ask Dhuck, he has a 5" lift also, sits higher than me, but doesn't have the travel I do. His brother has a 2" flexi coil that would out flex most 4" kits I've seen, but sits at probably an inch or so above standard.
    Yep, it's reality that you can still have a good lift and stay legal - just do your homework before fitting.
  4. The Following 2 Users Say Thank You to Bigrig For This Useful Post:
    ozzymalone (17th August 2012), patch697 (17th August 2012)
  5. #23
    330 Post(s)
    damn it i cant find the reference to Body Lifts........ Sh1t Bag!
    The proposed VSI 50 addressed Body lifts and Banned them completely. they also allowed to go to a 4" lift if you were a registered member of the 4WD Association in your state.
    I will find it and when i do i will post here. Until then may you shine in the glory of my humble acceptance of my Error!
    I Hunt you down
  6. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (17th August 2012)
  7. #24
    581 Post(s)
    Thats 1 for AB.... 44,729 for MR...LMAO.
  8. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (17th August 2012)
  9. #25
    The gap is closing in!
    Tappa tappa
  10. The Following User Says Thank You to Winnie For This Useful Post:
  11. #26
    Flexi coils sound ok, what are they like on the HWY????
    2" body lift is a lot of work, lifting and extending everything just to run 35s
    Most 4x4 run a 33 offroad which leave the tracks doable
    follow someone with 35s or 37s cutting up the track you'll be pulling out the winch.
    as AB said you'll get most places with a good 2" lift 33 tyres and buy a diff lock instead of body lift
  12. #27
    Expert Irvs's Avatar
    Jul 2012
    Parkdale, VIC
    I've got a 2" BL and 2" SL on 33's on my Mav (Tyre placard is 215/75/R16) and I passed a VIC roadworthy last week, given he was doing a solid for me though, he still put his pen to the paper therefore license on the line so clearly its either an arguable grey area or its legal.
    Sent from my GT-I9300T using Tapatalk 2
    1990 Ford Maverick, 4.2 Carby, 2" SL, 2" BL, Dual Batts, 33" Maxxis Big Horns
  13. #28
    Sep 2011
    I have 33's a body lift and eventually I will be getting a 2 inch flexy kit with 4 inch shocks. Imo a body lift raises the cog only a small amount. It keeps the sills a little higher off the ground and allows the fitment of bigger tyres. It is cheap and easy to do. And now in Queensland at least, very easy to make legal.
    Sent from my HTC Sensation Z710a using Tapatalk 2
  14. #29
    330 Post(s)
    To note during my reading last night the legislation talks about the measure of lift AND the measure of Droop in relation to factory spec! Not sure anyone will be policing that though!
  15. #30
    Sep 2011
    Maybe they will carry around a travel ramp or something. Lol.
