Results 11 to 20 of 30
Thread: is a body lift that great?
    330 Post(s)
    No in Vic you can have a 2" body lift, a 2" suspension lift and an increase in tyre size of 2" so 33s are legal in Vic
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    spoke to david from 4x4 etreme this afternoon and body lift is legal now and he can mod plate it. As a general rule you are allowed a 2 inch lift up here aswell. As for moding a 4 inch lift it is not possible up here. And yes I have some 35 centerpedes waiting for me in the garage.
    GQ Snorkle Lockers front n rear
  4. #13
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Thirsty View Post
    In QLD a 4'' is illegal, no matter what you do.
    EDIT; Suspension Lift that is
    I thought Scotty got engineered and legal with 4"
  5. #14
    581 Post(s)
    In Vic a 2 inch lift and 2 inch body lift is legal but a 4inch spring lift is a far better outcome.
    Finally I get to challenge MR...LMAO
    VicRoads' new VSI 8 regulation permits "Owner Certified" 4WD ride height increases up to 75mm, with 50mm maximum allowed for suspension lift, plus a 25mm increase resulting from fitment of a tyre with 50mm greater outside diameter, provided the modifications are undertaken using a commercially available lift kit that has been specially designed and tested for the vehicle application. Under the national guidelines, 'Owner Certified' lifts are limited to 50mm.
    A copy of VSI 08 can be downloaded from the link: http://www.vicroads.vic.gov.au/NR/rd...orvehicles.pdf .
    A copy of VSB14 can be downloaded from the link: http://www.infrastructure.gov.au/roa.../vsb_ncop.aspx
  6. #15
    581 Post(s)
    Quote Originally Posted by growlers71gq View Post
    If engineered and certified you are good to go if approved of course...
  7. #16
    Knew it! Thanks for having my back on this one Andy, somebody's gotta stick it to the rogues like MR!
  8. The Following User Says Thank You to Winnie For This Useful Post:
    AB (16th August 2012)
  9. #17
    581 Post(s)
    Quote Originally Posted by KRISTOFFA View Post
    He's been spending too much time with the rouge...lol....Just wait though he will pull something out of section 4.1.2 paragraph 17 line 4....waiting!!!
  10. #18
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    So did I. But David said even if they tell you its engineered its still not legal. Go figure
  11. #19
    330 Post(s)
    Buurrpp
    Hold that thought choppa!
    So 2 inch suspension that is a commercially available kit and 2 inch tyres so both of those are right.....
    Keep reading fella. On the iPhone but will go find the bit about body lifts....
  12. #20
    581 Post(s)
