Results 1 to 10 of 10
Thread: Painting Front Grill, what to do?
    Hey Groovers,
    My front grill on the Patrol is starting to fade, ive never painted plastic before.
    Any ideas on what colour or type of paint, etc?
    Thanks guys!
    CD
  2. The Following User Says Thank You to CrazyDave For This Useful Post:
    Bloodyaussie (5th November 2013)
    581 Post(s)
    I would use a grey or charcoal colour.
    Make sure you paint/spray a bonding coat to the plastic first so the paint can stick and dry otherwise It'll come off for sure.
    Also, if your going to go to the trouble doing the front grill you may want to do the other plastics so it all matches nicely maybe?
    For sure, good idea thanks mate!
  6. The Following User Says Thank You to CrazyDave For This Useful Post:
    Winnie (6th November 2013)
  7. #4
    Patrol Guru Timbo's Avatar
    East Melbourne
    Also, if your painting, don't forget to use Wax & Grease remover or Prepsol before you start scotch brighting the surface. Then again after you have scotchied the surface. This helps to stop rubbing in dirt into the plastic and causing a shite finish.
    You'll need plastic primer which is the spray bonding Andy mentioned.
    If you find out the colour code of your car (usually a paint code on the firewall in the bay) you can go to most auto paint stores and they'll mix it up for you. Some even put it in a pressure spray can for convenience. I'd recommend getting a can made up. It's easier to use than a gun and you dont have to worry about air and material mixtures. Use the same preparation as normal, but just use the spray can instead of gun... unless of course you're going to do more than the grille.
    Goodluck!
  8. #5
    Great advise, thanks a million G-Unit!
  9. #6
    43 Post(s)
    Quote Originally Posted by CrazyDave View Post
    Hey Groovers,
    Thanks guys!
    CD
    Stupid phone.. removed
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Quote Originally Posted by Westy's Accessories View Post
    Ow same here. A tow ball is for towing..
    Considering most blokes bolt 4T witches to there cars, his plane is floored to begin with..
    Hey Kallen, you sure you replied to the correct post?
    Jack
  11. #8
    43 Post(s)
    Quote Originally Posted by Apollofish View Post
    Haha.. my phone is having a moment.. lol
    Owner of
    Westy's Accessories
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    If you find after a coat or two that you're not happy with the finish, or you have runs, wait for the paint to dry completely, then use a fine sandpaper, 1200 wet and dry and rub the grill down while making sure the sandpaper remains wet with water. Can be done every coat to achieve an excellent finish, it just takes extra time.
    If you look closely at a cars finish, some have an orange peel effect, this can be cured with a wet and dry during the painting process.
  13. #10
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Spray the grille blade/s parts from "behind" first before anything, turn the grille all directions/angles to get all the nooks and corners (from behind), this will help stop any paint build up you will get on the front of the grille blades, instead of trying to do it all from the front.
    Plus then when you switch round to paint the front, you can focus a little more on the finish, rather than spot spraying to get inside all the hard to get to corners etc.
  14. The Following User Says Thank You to 04OFF For This Useful Post:
    taslucas (1st May 2013)
