13th August 2012, 03:16 AM
Advanced
Will a TD42 5speed fit a ZD30
Im thinking of buying a GU ZD30 with a nackerd manual gearbox and I have 2 GQ TD42 5 speeds in the shed. Will they fit in the GU. I would think the bellhousings would be different but is the gearbox the same?
If it does'nt go hard, Stroke It.
13th August 2012 03:16 AM
13th August 2012, 06:11 PM
I do recalll people saying the td42 would bolt up to the zd30 box so you might be in luck.
25th October 2012, 05:22 PM
Interested to know how you went ! Did it fit ?
Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
25th October 2012, 05:40 PM
They are the same box in the td42 manuals as what's it the 3l manuals so should go straight in you may need the bell housing for a 3l and the clutch to suit but should be all good
25th October 2012, 09:55 PM
Legendary
Definitely the same box. should slot right in.
Mic
26th October 2012, 07:13 PM
Its mostly the engines that are stuffed in zd30 GUs not the gearbox.
Sent from my GT-S5830 using Tapatalk 2
7th October 2015, 12:37 PM
nissannewby
Hey Newby. .
My gearbox has some issues and after taking to MR it's probably best I source a good second hand one..
Any idea when nissan recified the weak 5th? If the crd box fits my bell housing etc then it'll open my range and hopefully find a newer box..
Plus as soon as td42 is added to any part the value doubles as we all know so hopefully the 3ltr will be cheaper..
Also any idea on the 2.8td gu boxes? Same same or different?
7th October 2015, 10:25 PM
Late 03 I believe the box was rectified. So any manual from a 4.2, 3.0, 4.5 or 4.8 should bolt up. So you have quite a few options. The 4.8 does have slightly different ratios.
2.8 boxes are different. Much smaller.
The Following User Says Thank You to nissannewby For This Useful Post:
BigRAWesty (7th October 2015)
7th October 2015, 10:28 PM
nissannewby
Cheers bloke
