Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Inlet Manifold clean
    Patrol Guru paulyg's Avatar
    Ballarat
    Just finished removing and cleaning the inlet manifold, before that I removed the egr to manifold pipe to have a look, yep needs doing i will try one of those cleaners in a can it cleaned the throttle body ok but did nothing to the manifold.
    I did notice a lot more sludge in number 3 and 4 ports, probably why pistons 3 and 4 crack.
    Have not driven to far yet but the egt seem to be about 50c cooler.
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    Paulyg,
    Try using brake cleaner, it should do the job cleaning the inside of the manifold. Not treating you like an idiot but make sure you remove the manifold to do the job.
    Mark
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
    Ballarat
    No problem mc97gq, took off the manifold and used degreaser that i already had, took a couple of goes but it came up very good, the cleaner in a can was threebond diesel engine conditioner.
    I wanted to try it just to see what if anything these products will do which is not much, I have blocked the egr so should not be a problem any more.
    Motor has only done 85000 km surprising just how much sludge there was.
    Hardcore
    central coast nsw
    2 Post(s)
    There is a marine engine cleaner available that foam fills a outboard engine to clean it out.
    I used it some yrs back cant remember the brand sorry.
    You spray most of can in running motor, shut down, spray rest to empty can let soak , and re-start engine to flush.
    Now before you tell me bad Idea, remember the cost of a 150hp outboard engine is more than a small car and if it was so bad I doubt a marine mech would use it on something that takes people 20 N-Mile offshore.
    I had it done to a 150HP merc, no harm was done.
    The cleaner is also used to clean out a engine that has been in "winter-ised" storage.
    There are marine storage spray products, that protect from no use of engine.
    Cleaner May be of some use here!.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  6. #5
    Hardcore
    central coast nsw
    2 Post(s)
    Another Idea is if you are removing a manifold.
    Oven foam cleaner.
    Used this on 2nd hand engine pipe that had bad build up of soot took a few applications as it was thick but did work.
    the foam is a good way to get coverage on the inside of a pipe and cheap.
  7. #6
    Unafordable
    4 Post(s)
    Petrol is very effective cheap cleaner in this case just follow usual precautions.......
    Hardcore
    central coast nsw
    2 Post(s)
    Nulon Foam Cleaner
    Here's a can of Nulon product.
    $10.95 at local auto spares.
    Haven't used it yet so can comment yet.
  9. #8
    Lake Macquarie
    Subaru also do a cleaner called top end cleaner the part number is sa459 , this is one of the best products out there , will remove fuel varnish gum and pcv build up , we have seen it remove locked pistons on subaru boxer engines that were unadle to be turned over , this is a foam type cleaner as well . regards jase c
  10. The Following User Says Thank You to jasec For This Useful Post:
    Robo (3rd October 2012)
  11. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by jasec View Post
    Best stuff ever. But hard to find unless you know someone..
    Sent from a device which doesn't always agree with my thumbs...
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
  13. #10
    Ballarat
    Is this Subaru top end cleaner for petrol or diesel motors?
