Results 1 to 3 of 3
Thread: Nissan PTO gearbox lubrication source
    193 Post(s)
    Can anyone confirm the lubrication for the actual PTO gearbox on the side of the standard TD42 box receives lubrication oil from the main gearbox as I cant recall seeing a fill point? There appears to be a little sump in the casing however I am thinking this may fill from carry over of the gears when they mesh with the main gearbox gogs. None of my manuals, Gregory, Haines or Nissan mentions this - or at least I cant find the reference. Thanks
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    From memory, even though they're high up, their fill level is supplied by the main box. I'll jump under shortly and have a look.
    1989 LWB 5-Seat, TD42
  4. The Following 2 Users Say Thank You to mihit For This Useful Post:
    BrazilianY60 (26th September 2023), PeeBee (25th September 2023)
    193 Post(s)
    I also think this is the case, just chasing down an issue that has arisen. I think the problem I have with selection between forward and reverse is cable jacket lubrication however I initially feared it might be from a poorly lubricated gearset. Anyway, pls advise what you find, I am going to lub up the cable assy tomorrow and see if it improves. Thanks for the effort, greatly appreciated
