21st October 2010, 03:35 AM
21st October 2010 03:35 AM
21st October 2010, 08:53 AM
The different seals will be from different manufactures, as long as they are both made to the same spec they should both do the job. As to why it now leaks continually with a series of new seals, that's anyones guess! How does the axle look where the seal runs, is it scored? If you can't get the Nissan seals to hold, try getting aftermarket.
Another possibillity is you may have a slightly bent diff housing.
Tony
21st October 2010, 04:13 PM
Is the outside diameter of the new seal the same as the old one? they look different sizes. Is the housing original? Could be out of a different model.
Had problem yesterday at work were a axle had broken, got a second hand unit from another GU but it would not fit.
21st October 2010, 10:51 PM
just thinking outside the box, is there any evidence of damage to sealing surface? Are you using a new seal every time? as 2nd hand ones can be damaged.
Otherwise I can't offer anymore than what's been said already.
22nd October 2010, 05:06 AM
