Page 16 of 16 FirstFirst ... 6141516
Results 151 to 154 of 154
Thread: Robo's ride
  1. #151
    Hardcore
    central coast nsw
    Large rear barn door was not locking in the top catch.
    After a lot of adjusting the horizontal guide and jamb catch etc.
    Then finally removing the catch cover from door itself to see it sticking in the unlocked position .
    Good spray of dry lube and sweet again top catch now locking as the nissan gods intended.
    believe this may be a common issue.
    tell tale for mine was a squeak in the top latch.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Hardcore
    central coast nsw
    Removed volt meter from oem cig lighter hole, replaced with new usbx2 socket that includes a volt meter built in.
    Also added 2x cig plugs beside that.
    All switched & fused individually.
    = 2x 1.0 amp usb.
    2x 2.1 amp usb.
    2x 12v sockets.
  4. #153
    Hardcore
    central coast nsw
    Rear large barn door had a noise/squeak in the tension arm slide.
    Not the locking arm on the bottom of door.
    The arm slips through the middle of a small rectangular block housed inside the door cavity.
    Within the box are opposing springs with a nylon block and a roller bearing each side of the arm.
    The spring & bearings apply pressure to the arm to slow door movement etc.
    I disassembled it to find----
    Trouble is the bearing is only mild steel, in-turn it can stop turning and then flat spot against the arm.
    The flat spot grabs on the arm when you open/close the door creating squeak/chattery noise.
    Disassemble, replace bearing with a offcut from a tensile bolt shaft.
    Clean, re-grease, reassemble, Good to go , no more squeak.
    In hindsight next bearings you replace from another job keep some needles you never know when ya might need 1.
    Bearing is 7mm dia x 16 mm long.
  5. The Following User Says Thank You to Robo For This Useful Post:
    barndog1963 (8th March 2018)
  6. #154
    Hardcore
    central coast nsw
    Did a testing the weekend towing the outlaws much smaller/full height 2 ton 18ft van.
    Same test as before up ourimbah hill sitting on 90kph.
    outside temp was about 27 again so equal test.
    Good new temps were much more moderate 85-90 Deg C.
    verdict was simply me pushing to hard with much larger/heavier load in the past.
    cruising along was 82-85 C depant on grade so again all good.
