25th July 2012, 09:26 PM
mk sd33t edic motor un connected in run possition?
hey if i had the wires not connected on my sd33t to the edic motorwould it be in the run or stop possition? cheers
25th July 2012 09:26 PM
25th July 2012, 09:29 PM
Hardcore
Stop position is fully back.
Cheers, the ferret.
25th July 2012, 11:01 PM
as in towards fire wall? with tension on springs
25th July 2012, 11:39 PM
Hardcore
mqturbo
SD33T has two positions, forward is run, Back is stop.
SD33 NA has 3 positions, forward is start, middle is run and back is stop.
If you remove the linkage, you should be able to feel a slight "detent" at the run and stop position, the stop position may have a slight spring resistance.
If you crank it over and white smoke comes out the exhaust, there is fuel entering the cylinder, white smoke is one of two things, low compression, or un burn't fuel caused by not enough heat during compression to ignite.
A low battery will cause this, as will sad glo plugs or ancient fuel, a squirt of "start ya bastard" or "aerostart" or a very slight sniff of petrol should get it to start (on a rag)
Provided you have bled the fuel system, you have good compression and a good battery, it should start.
Have you messed with the timing? (injector pump).
Have you got all vacuum hoses from the throttle body connected to the injector pump.
How are the fuel filters, tight??
At the base of the fuel primer, there is a gauze filter, make sure that is clean. it's inside the bottom banjo fitting at base of primer pump.
Cheers, the ferret.
14th July 2014, 08:40 PM
hey guys im not sure if this should go here but im looking for info on the dcp moduel that controls this part of the system.. has any one seen info on replacing or repairing the relay pack in these modules
