9th November 2012, 07:16 PM
#321
Lowy44
Where'd ya get the led's from for the bullbar lights Fletch?
Got the LED bullbar lights through my work, however can get them from Autobarn or Bursons.. They are made by a company called LED Autolamps and the part number is 175AW
Fletcha
Qualified Auto-Electrician
Apprentice Sparky
Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
9th November 2012 07:16 PM
9th November 2012, 07:22 PM
#322
Well instead of buying a catch can being i like to build things i decided to make one haha.. Its made from PVC pipe with caps both ends and filled with Stainless metal Scourer's.. Copied the design from a another member of an un-named forum and aparently works well.. Time will see
All up cost me about $50 and ill get 2 out of it as i will make another for my housemate TUR7LE
Few Pics
The Can
All Plumbed up
You can see the clear drain tube coming out the bottom
The Drain Tube with a tap on the End, will eventually be plumbed back into the sump
Pic of my Glowing bonnet scoop when its actually dark haha
Apprentice Sparky
9th November 2012, 07:47 PM
#323
This will be a good exercise to compare between your home made and my provent
but why would you want to put dirty oil back in the motor ? Ive had the provent for a while now
and ive noticed the oil level dosnt drop in the motor but the mix of diesel and oil fumes that come from the rocker
cover turn to a black oil which in turn will contaminate your nice new clean oil and you,l need to change
earlier than you thought
9th November 2012, 08:55 PM
#324
88 GQ patrol 4.2l Carby 2" suspension, 2" body
The Following User Says Thank You to TJH For This Useful Post:
big_fletch (9th November 2012)
9th November 2012, 09:01 PM
#325
roofy
Yer thats a good point Roofy, ill see how it goes after a couple of thousand k's and decide then.. Might just leave it as it is for now.
Next ill be pulling the butterfly out of the Swirl valve and hopefully should help a little in the lower revs.. Then my intercooler as its leaking pretty bad now.. Time for a ASE upgrade lol
Apprentice Sparky
The Following User Says Thank You to big_fletch For This Useful Post:
Sir Roofy (10th November 2012)
9th November 2012, 11:35 PM
#326
21st April 2014, 10:18 PM
#327
Hey Fletch, tough looking wagon mate. Can you post up a pic of how you ran power to your roof rack lights? Ive just got my rack and am looking at how to do the same....
