The reduction is the transfer case gearing, so 85% means 85% more teeth, as seen in Macca's pdf, original ratio of 2.02, 85% reduction gives 3.743 ratio. It ends up around 54% of original speed. From the pdf, standard, 35.4 rotations from the motor gives 1 at the wheels, with 85% reduction, it now takes 65.6 (1.85 times more) rotations to make 1 turn of the wheels. You're close to doubling (1.85 times) how many rotations it takes, thus you're close to halving the speed.
That's my understanding, correct me if I'm wrong.
Same process, 43% reduction leads to 70.6% of original speed. 24% reduction leads to 81.3% of original speed.
Thanks Macca and thanks outrage for explaining it gives mr more to think about
Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
WARNING: Towballs used for recoveries,can and do kill people and damage property
I have the 3.743 ratio in my GU - one of the first batch Marks ever made for Patrols, back in Oct/Nov 2002. Awesome if you want to go slow, and rock crawl, but most normal offroad use requires 3rd gear takeoffs, even on 35" Centipedes.
Was funny seeing my boss trying to drive it when I left it in L4 though....
I done an excel spread sheet comparing different transmission/dif/transfer combinations, will try and find it and post it up. I do remember my 4.5 petrol auto was shocking compared to the manual, manual runs at 65% of original speed (of the auto) in first (no reduction gears), 85% gears in the auto bring it to the 54% of original making it a bit slower than the manual.
Ended up, 24% reduction in the manual was equivalent to 85% reduction in the auto...
Delayed response, finally remembered it. Couldn't actually put the spreadsheet up, but gives an idea of some engine/transmission combos (only some of them).
I have the 43% in a gu td with 33, Made it a really nice 4WD go down the steepest hill in first full control with no brakes, crawl up in 1st or 2nd and will still do 40-50 in low 5th, withy the 80% you will have to change between high and low range more often
