22nd July 2012, 10:34 PM
Advanced
rust repairs
hey is there anywere that sells rust repair panels for mk patrols gunna need a couple after todays inspection
22nd July 2012 10:34 PM
22nd July 2012, 11:34 PM
23rd July 2012, 01:12 PM
a member of the menagerie
silly one,
Just thought I would let you know I have just dealt with about time spares as per 97_gq_lwb post.
Mate ordered some stuff on Thursday for my GQ it arrived today, well packaged, prompt and fairly cheap.
So I have no hesitation recommending them as a potential parts supplier.
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
23rd July 2012, 06:13 PM
silly one
Have a look on egay, theres a few selling lower front guard and rear 1/4 lower replacement panels
But sometimes you can snag a rust ,dent free guard cheaper than the repair section
What exact areas you talking ???
23rd July 2012, 09:13 PM
Advanced
hey i can make the easy parts just was looking to see how the body bolts up so i can do a lift kit and both sides nearest the sill were pretty much stuffed and the brackets where the body mounts to was considering just flat steel but yeah not real sure how good itd end up gunna pull the front carpets out hopefully on the weeknd to se how bad it realy is so long atory short need both front floors lol
23rd July 2012, 09:15 PM
Advanced
are mq floors the same ?????
24th July 2012, 12:17 PM
Noone i know of makes over the counter rust repairs for the sections you mention
Its a common problem for this series to rust in the floor area and the body mounting points, not only at the radiator support panel, the mounts just under your feet , front floor ,and the mounting points just behind the front seats
Nearly every MQ/MK has rust in these sections, but theres just not enuf demand for people to tool up and make these sections
MQ/MK front floors the same, wether shorty, wagon or ute
The doubling brackets on the floor pans, underneath can be pressed up and home or self made, or you could sounce some 2nd hand sections from a wreck
The other issue youll find, although the floors look good,the factory floor deadener hides alot, once you start removing it for repairs and belting stubborn old body mount bolts you could discover more than youll like
Most floor repairs are done by just flat steel sections or from a wreck
24th July 2012, 02:47 PM
