22nd July 2012, 01:34 AM
Top and bottom radiator hose sucking in on themselve
I think I opened a box of worms when I popped the hood on my Safari this week.
One more issue I just found was that the top and bottom radiator hose is suckin in on themselves once the engine cools and I have to remove the radiator cap and they expand back to their right size, I got a new cap in the hope the seal was forked but it's still doing it, the hose looks new and properly fitted, is it just a weak hose or is something sinister lurking, I cant see any leaks as of yet as its night but the water level has stayed the same. Any ideas.
again huge thanks
22nd July 2012 01:34 AM
22nd July 2012, 02:04 AM
Could there be something blocking in between the radiator neck and the reservoir tank..??? Preventing the system to vac in the coolant as the engine cools down...
The Following User Says Thank You to Ade For This Useful Post:
eliurquhart (22nd July 2012)
22nd July 2012, 08:26 AM
I'd say buggered hoses if all else is ok they tend to get soft i had a top hose that would swell up it had never been used and was in the back of the car when i got it as a spare replaced it with a new hose and it is fine now.
22nd July 2012, 09:32 AM
Goodaye make sure you check the hose from the overflow tank sometimes if you remove the lid and put back on it can kink over thus preventing it sucking coolant out of reservior as it cools down, it happened to me.
cheers honest
22nd July 2012, 10:20 AM
Dependinding on what brand the hoses are, sometimes the spring is removed .
22nd July 2012, 11:04 AM
these dont have a spring in them thats why I thought it might be weak hoses
silicone or normal with spring, any comments?
22nd July 2012, 11:12 AM
Hardcore
eliurquhart
Mate, you could try a spring from another hose and see if that solves the problem.
Sometimes the el cheapo hoses do this, but everything else sounds ok.
Cheers, the ferret.
22nd July 2012, 04:50 PM
Cheers all, Ade was the winner, the hose was clogged through to the reserve tank and the cap was blocked with absolutely no flow going through that, got some bonzi wire with a cloth attached through at one end and threaded it through with degreaser on it, cleaned it out like a charm. So will see if that fixes it, also think that with all that gunk maybe theres more but the radiator fluid is clean as so ill wait and see before I flush it.
Nice work Ade, chur bro
22nd July 2012, 04:53 PM
I cut any hoses used for sucking on an angle so that this doesn't happen. Good info though definitely.
22nd July 2012, 05:00 PM
Mmmm..hope that was the real culprit Eli. Better still check your cooling system thoroughly..
