17th June 2010, 02:08 PM
Where is the fuel pump relay?
Hi Guys,
Ive noticed that my fuel pump is not priming on my 2001 GU
The fuse is ok but but ive checked the wires going to the pump and there is no power.
I'm guessing that maybe the relay has packed it in?
Does anyone know where its located, been searching everywhere...
17th June 2010 02:08 PM
17th June 2010, 02:18 PM
Hi Nizzo (welcome to the forums too)
This happened to a mate of mine and we found some info about this. In the workshop manual it shows it plugging into a junction block above the accelerator pedal area above the fuses. It shows it in a group of 5 relays with one in each corner & the 5th in the centre. The fuel pump relay is shown as the top inside piece. (closest to the steering column)
See how you go. Been a while since I've needed to find that out again.
17th June 2010, 08:51 PM
Legend, found it, thanks for that
