Results 1 to 10 of 16
Thread: Delay in Accelerator Pedal Once engine Hot??????????? HEAT SOAK???
    Jul 2012
    Hobart Tasmania
    Ok so this has happened a few times. basically, every morning i drop the kids of at school. This means driving and then stopping for 10 minutes to drop them off before i continue on to work.
    What i have found is that once re-started after standing still for those 10 minutes, there is a delay in throttle pedal response. basically, you can push the pedal down say 1cm and nothing happens.
    This only happens after standing.
    I am assuming this is due to the Interwarmer getting heat soaked to buggery and the charge air being VERY hot.
    Has anyone else had this issue. No issues like this when started in the morning and just driving.
    HUMM me thinks it's time for a bigger IC and a fan.
    Hardcore
    central coast nsw
    More info, engine and model ?.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Jul 2012
    Hobart Tasmania
    Opps 2012 GU patrol 3L CRD manual
    Beginner Ciapek's Avatar
    Don't know if this helps you.
    Mine is a 2010 3ltr CRD Auto.
    Over the last few weeks, the throttle response had developed some 'flat spots', and on two occasions the RPM "hang" after coming off the throttle.
    Went straight into the dealer, they had the car for a whole day and as you would expect, could not replicate the fault.
    After a heated discussion we went out to the car, I started her up and with my hand pushed the accelerator pedal SIDEWAYS.
    RPM hung at 900.
    Diagnosis, faulty potentiometer on the accelerator assembly, part replaced on the spot, all good since.
    All work covered under warranty.
    No hint of problems since.
    Don't know if this helps you, but they had spare parts in stock, and that tells me that they know that they are having issues with the accelerator pedal assembly's.
    Cheers, good luck.
    Advanced roon's Avatar
    Jul 2012
    pakistan peshawar kpk
    its cause bcz of low fuel in tank or block fuel filter
    Jul 2012
    Hobart Tasmania
    Car has only traveled 7000km and fuel was half full.
  8. #7
    newcastle
    throttle lost,
    [QUOTE=Ciapek;247917]Don't know if this helps you.
    RPM hung at 900.
    Cheers, good luck.
    gday Ciapek
    just wanting to ask hows your pootrol going after throttle assembly was fixed ?
    i brough a 2012 CRD auto new in june this years and for the last 1200 mine has been losing the throttle
    off lights etc only with a slight foot pressure, same thing dealer could not fault it,
    car now has 6000kms on the it,
    hows yours going now ?
    cheers daryl
  9. #8
    Wouldn't it be Mr Nissans problem? being a 2012 model
  10. #9
    newcastle
    yes that it is, only 4 months old, 6000kms now,
    but they cannot find the issue, or any fault codes
    im going to leave it with them for 2 weeks to drive around see what they say then,
    same story with shifting issue in tranny (auto) but both maybe linked to TPS
    well i am hoping, anyways
    cheers daryl
  11. #10
    Legendary happygu's Avatar
    WogsRus,
    Did you get yours fixed?
    I have never noticed the same problem with mine.
    Mic
