4th August 2012, 08:46 AM
#21
Apparently the LED bar has an optional choice spot light or flood light.
4th August 2012 08:46 AM
4th August 2012, 08:51 AM
#22
Banned
Rusco
Fixed either way - but spot or buy spread (or a combo) and it stays as it lays from there (i.e. you can't change the LED's once in and there isn't a switch to choose between the two once fitted).
21st August 2012, 07:05 PM
#23
The spot or flood is determined in the actual lens of the LED not by a switch, you can get euro beams which are usually floods on the outside edges and spots in the middle section when it comes to LED light bars
1990 Ford Maverick, 4.2 Carby, 2" SL, 2" BL, Dual Batts, 33" Maxxis Big Horns
