12th July 2012, 10:32 AM
RHR barn door check strap mount broken??
Hi guys,
I have just relised the my right hand rear barn door check strap mount is broken or loose, on my gu 98, I have had a quick look at it, but can't see any bolts or even a way to resecure it??
Does anyone had this problem and I do they know if it's tac welded on?
Cheers!!
12th July 2012 10:32 AM
12th July 2012, 11:02 AM
Hardcore
If it's come away at the pillar side, you need to remove the tail light to gain access and drill and bolt it back into position.
Bit of a pain job!!
Cheers, the ferret.
12th July 2012, 01:14 PM
Cheers ferret!!!
Much respect!!
15th July 2012, 08:56 AM
Do you know anyone who works in a fab or panel shop?
If you do get them to throw a couple of nutserts in it. It then only requires working from the outside and a little bit of rustproofing.
Cheers Mick.
