11th July 2012, 01:19 PM
Fuel Line Bleed
Can someone tell me if the GU patrols have self bleeding fuel lines in case you run out of fuel in a diesel?
I used to cruise... NOW I PATROL!
11th July 2012 01:19 PM
11th July 2012, 01:23 PM
Yeah big black plunger thingy on top of fuel filter
11th July 2012, 01:26 PM
So whats the process, just pump it a few times and try and start it up?
11th July 2012, 01:31 PM
Yeah basically will be spongy at first and will then firm up making it harder to depress
11th July 2012, 02:42 PM
Ok thanks for the info. Sorry for starting a new topic about it
11th July 2012, 03:30 PM
If you actually run it out of fuel its usually best to crack injectors. You can get away with just pumping the primer on the filter til its firm but it will take a fair bit to start.
The Following User Says Thank You to nissannewby For This Useful Post:
threedogs (11th July 2012)
