9th July 2012, 03:23 PM
#11
4 hrs Work maybe even at $100 an hour, no where near $750
9th July 2012 03:23 PM
9th July 2012, 03:52 PM
#12
Just gave it another degrease and had a bit more of a look. It appears that the front seal is leaking a bit too. I thought it was the sump gasket that was leaking but i reckon its the front seal leaking and running around the lip of the sump.
Ive lined a mate up to do the rear seal. Im guessing the front seal can be done at a later date as there is no doubling up on labour etc?? (sooner rather than later as its already weeping)
Hello from Under Down Under!
9th July 2012, 03:56 PM
#13
You can buy shims for these can't you? My mate did on his 302 powered 75s ute
9th July 2012, 04:12 PM
#14
Just priced up seals. Genuine from nissan: Front $32, rear $77. Not bad for genuine.
9th July 2012, 05:17 PM
#15
In our workshop and others in my area, removal of a 4x4 gearbox will usually vary between $450 and $650, add to that the cost of removing, cleaning and reinstalling the sump. Plus cost of the gaskets and seals. Sounds about right to be honest. Patrols are knowns to leak at the front seal, I have seen a few sump gaskets leaking but more commonly front and rear main seal.
The Following User Says Thank You to Gas_Guzzler4800 For This Useful Post:
