Results 11 to 20 of 21
Thread: ZD30 catch can
    Jul 2012
    Catch Can
    Has anyone used a fuel filter as a catch can? Does it serve the purpose? FUel filters are much much cheaper than catch can. Is the filters used in air compressors the one referred to as catch cans?
    Thank you.
    Sort of, but most here use the Provent 200, these are add ons to help prevent the MAF from getting dirty.
    Catch cans are affordable ,cant see why you'd need to use fuel filter type
  4. #13
    Caboolture, QLD
    Quote Originally Posted by Rumcajs View Post
    The important part is to consider which ZD30 Patrol you have as onwards from GU4 version the engines no longer have the hole in the block for the drain to be connected as the previous versions. So in that case the alternative methods of draining the Provent needs to be figured out.
    Am about to put a catch can in Thelma. She's an 06. So can someone fill me in on the 'alternative methods'...
    Are you ready for Christmas?
  5. #14
    Aug 2010
    adelaide
    300_0093.JPGjust run the hose down and out through the wheelarch and put a tap on it to drain
    OH LEATHER IS NICE
  6. #15
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Hi i ran my hose in the same position but a bit further
    along the chassis and then tapped it
  7. #16
    Advanced Lowy44's Avatar
    I fab'd my own, using a generic turbo catch can from supacheap. Search me on the WApatrolforum if your interested in how I done it.
  8. #17
    Unafordable
    4 Post(s)
    Quote Originally Posted by Mechlou View Post
    Here is my effort --> Run the hose down the mudguard and chassis. Not seen but easily reached.
  9. #18
    Sep 2020
    I know old thread but anybody know where you can get the 25 to 12.5 reducers please
  10. #19
    Quote Originally Posted by Niftyjk View Post
    Get some XF Flacon heater hoses mate. Might be XE. Can’t remember. These are straight hoses which are 13mm - 22mm. Good enough for the Provent can. Works well.
  11. #20
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I got the flashlube pro one. A comparison I was reading at the time had the flashlube catching more oil than the provent (at slightly more pressure drop), so that's what I went with.
    All fittings and what not can be had from ebay.
    2008 CRD Auto Wagon
