1st July 2012, 12:16 PM
goodyear wrangler mtz with kevlar
Ok guys i have bought a set of these tyres and my question is about the pressure they should be at, i just checked mine after the 50km check of wheel nuts and checked the pressure and was surprised to find the pressure at 44.5 ( warm) psi, i was a bit surprised by this and i will ring the tyre shop on Monday about this but thought i would put it to you guys first,, so what ya reckon???
and if this is the correct pressure what would i drop to in sand etc??
cheers
1st July 2012 12:16 PM
1st July 2012, 02:52 PM
Hey mate i got a set of wrangler duratracs on my ute and on road i run 40 psi , about 24 off road and bout18- 20 on sand, because then if you run into trouble in the sand you can drop psi more to say 12 to get you unstuck .
Sent from my GT-I9100 using Tapatalk 2
The Following User Says Thank You to CorbinsGUte For This Useful Post:
1st July 2012, 03:15 PM
1st July 2012, 04:40 PM
44 is probably a little high. x2 on growlers for comfort and wear usually around the 36-38 psi mark.
15th July 2012, 07:57 AM
I run 38 to 40 psi on road and 28 to 30 on corrugated dirt roads. This seems to work well for my 33" mtr.
The Following User Says Thank You to TimGU For This Useful Post:
Malgreen (16th July 2012)
