Results 1 to 10 of 10
Thread: leaking headlight
    Sep 2010
    Adelaide, South Australia
    leaking headlight
    been out four-wheelin two nights in a row now and have busted a globe each night from doin creek-crossings.
    have taken the lamp out and theres no cracks in it, and the rubber cap seems to be fixing well.
    anyone had this problem and/or have any tips on how to make sure its watertight?
    cheers.
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Have a look at this thread... might help
    http://www.nissanpatrol.com.au/forum...ight=headlight
    ________________________
    ______ 2017 D-Max _______
    Sep 2010
    sweet yeah thanks, theres some good info in there. my problem is more that as soon as the water gets in, the cold on hot busts my globe straight away. so im trying to keep the water out all together... its possible ive just gone in a little too deep tho... =)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    sealed beam headlights is the answer............ i went from sealed beams to h4 globes, every time i done a river crossing, blew the globe. went back to sealed beams, no trouble.....
    Are you running sealed beams or something else????
    Oct 2010
    Are the fuses working ok?
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Definitely go sealed beams ... just did the same myself (about 8 weeks ago) as I always have the lights on when I'm out on tracks, and low and behold - no more blown bulbs ...
  8. #7
    Advanced mudtrolluk's Avatar
    Nov 2010
    Essex, Uk
    I've sealed all my lights with silicon, drilling holes didn't work as the mud pluged it and was to dirty, so striped cleaned then filled all holes with silicon. Cheep as chips.
  9. #8
    Expert 89GQ's Avatar
    Adelaide South Aus.
    My Narva semi-sealed are good through water, well touch wood! But they have a good rubber boot the globe slides into.Bigrig, are the sealed beam just standards or can you get higher wattage ones??That was the reason i went semi-sealed for the H4 Globes instead of the candles that were in the sealed units!
    89 GQ TD 42
  10. #9
    Banned
    You can get sealed beams in a range of wattage & colors now so you can get a light that work for you but if you blow one its a headlight change (a small down side hay)
  11. #10
    yep the only way is sealed beams and turn them off in the water
