28th June 2012, 06:57 PM
#11
How's the serenity
So you are still recieving vacuum via the vac control solonoid ?
28th June 2012 06:57 PM
28th June 2012, 07:00 PM
#12
Not sure, tell me how to check and I'll do it tomorrow, losing power but still choofs along ok, disconnecting the battery over night.
28th June 2012, 07:07 PM
#13
How's the serenity
just left of the air filter housing body with wiring going to it and your vac lines going in and out of it opposite the wiring . this is where your ecu controls your boost in conjunction with the egr valve operation .
28th June 2012, 07:16 PM
#14
Is that the thing with the three vacuum hose outlets on it?? I saw somewhere a looped vac tube on this after fitting Dawes
28th June 2012, 07:31 PM
#15
How's the serenity
28th June 2012, 07:48 PM
#16
Do all three need a hose going to it, have notice vac hose with round green filter just lying in engine bay, cheer
28th June 2012, 07:54 PM
#17
Does that need vac hose on all 3, saw 2 of them looped somewhere , vac hose with round green filter just lying there, EGR is blocked
Reason: add info
28th June 2012, 08:24 PM
#18
How's the serenity
so you have vacuum hoses just lying there not hooked up to anything ?
28th June 2012, 08:34 PM
#19
Yeah that one with the small green round filter in particular, first I noticed hose going to turbo loose brought a GATES hose clamp an fitted today, all these things removed to change alternator,got no clue where everything goes. Last truck was a 350 chev 75s troopy plugs only , I did not change the alternator 4x4 shop did
28th June 2012, 08:36 PM
#20
How's the serenity
