27th August 2015, 05:38 PM
#401
Nasty Dog - Moderator
The Following User Says Thank You to Woof For This Useful Post:
27th August 2015 05:38 PM
27th August 2015, 06:17 PM
#402
Dribble Master
Tuppa
bloody hell Doggy, wash your car mate!!!!!!! hahahahaha
1st September 2015, 12:56 PM
#403
@ Tuppa good news and bad, You have the one motor bar combo I cant fit one of my points to.
Good news is I have a proto type thats nearly finished, I'll get some MDF samples cut and post to either
yourself or OD to check for fitment,
I know of no one with the same combo over this way, but a few members have the same.
Ill PM when I have the MDF samples.
Its all to do with that 30mm lip, personally I'd cut it off and fit my "tee" shaped ones,
but some dont like cutting bits off their Patrol lol
Woof (1st September 2015)
9th September 2015, 11:03 AM
#404
Hi all just an update , the Y62 are being cut and should fit first time and very strong IMO.
Also for ppl with the model/ bulbar combo like Tuppa Ive gone to the Laser cutters and picked up some MDF samples.
As OD has the same combo I'll either fax or email what I have so he can adjust to suit, all I know is the hole centres are right
just not quite in the right position. So bear with me for a while and I'll have points to suit all GU's regardless of the combo.
Its difficult getting hold of all the different Patrols as you could imagine.
FYI the Y62 I'm looking at has already done the front pinion seal and CV seals , bloody thing is brand new
Must admit he is ex comp truck driver[very good] so pushes hard off road.
Yet no excuse to be blowing seals, this Y62 is having a blower fitted soon
9th September 2015, 06:11 PM
#405
That's the same as mine Tuppa.
Cheers Rod
_______________________________________________
Bitumen ...... Another watse of public funds
My Build 2005 TD42TI
9th September 2015, 06:29 PM
#406
Rocket55
Hey Rocket you have the T one's is that right.
Tuppa cant fit them as there is a 30mm lip near the two bolts
on the third picture
9th September 2015, 09:09 PM
#407
threedogs
No mate, mine is exactly the same as Tuppas, 2005 TD42Ti with and ARB bar with that lip on it.
Cheers Rod
9th September 2015, 09:18 PM
#408
I'm pretty sure mine are the same John as I have the same combo. So without chopping it won't fit ??
20th September 2015, 05:19 PM
#409
Just had a quick look and unsure whether I'm doing something wrong here but this doesn't look like it would fit ? Thoughts TD ???
That bit of metal i circled in red on second photo, the poin'ts wont make it in there with that there ? Am i lining these up wrong or ?
20th September 2015, 05:29 PM
#410
Here is a bretter photo of the prior one. Circled in red is the bit of metal in the way. Fair bit of metal off the bull bar bracket.
